  • Stranded in Cody,WY Transmission/electrical
    Posted by Ron on July 11, 2021 at 9:25 am
    I’m posting this for my parents who have a 2002 XLII single slide Royal. The cell reception is a bit limited where they are so if you have any ideas or think you can help i can get the info to them or have them contact you. They are in a driveway at relatives.
    They have been in contact with Prevost, Allison, a local mechanic and a service person from Billings Mt.
    Here’s what’s happened over the last 10 days.
    Here is a picture of the box. Shift selector pad shows only zero and no buttons on there have any response. Internal wire harness and temp sensor have been replaced with no change. Also transmission brain box replaced with no response.
    The next plan is to have the Detroit ECM checked to see if there is an issue there.
    Does it sound like they are on the right track?
    Thanks in advance for any help/suggestions
    Charles replied 5 years, 4 months ago 6 Members · 6 Replies
  • Ron
    July 11, 2021 at 11:49 am
    Have they tried another keypad? I see a list of things that have “happened” over the past 10 days. Work done over ten days or has the problem been getting worse, or did it just quit all at once?
  • Jon
    July 11, 2021 at 12:34 pm
    It’s been the same problem the entire time. When the got there he parked and a few hours later was going to move the coach a few feet and when he started it is when the problem started. He did try a different keypad but still did the same thing.
  • Charles
    July 12, 2021 at 11:35 am
    Update: The ECM, the Allison computer, and keypad were all tested this morning and all show they are working properly.
  • Loc
    July 12, 2021 at 12:22 pm
    I’m trying to grasp everything you guys have checked but there are 3 transmission sensors on the B400 which I think he has.
    These faults don’t show up in error codes and act as you describe. I changed all 3 of mine and had a no shift problem. Mind you with these issues no 2 are alike only having like fault characteristics.
    Until I reached on top of the trans and played with the harness going into 1 of the sensors did we solve the problem. Then rewired the harness. This was on an 06 chassis.
    Later
    bv
    July 12, 2021 at 2:30 pm
    Bernie! Would it be possible for him to give you a call and ask you a few questions?
    If that’s alright text or email me a number and I’ll pass it on.
    July 12, 2021 at 4:02 pm
    yes sure , sent
