  • Starting problem
    Posted by Eric on July 21, 2024 at 7:49 pm
    For a few months, I have had a problem engaging the starter. Sometimes I will turn the key and the starter engages the first time. There are other times, I have to turn the key off and try again, sometimes four or five times. Since the starter was still the old style, I went ahead and put a new one in. This has not fixed the problem of it not always turning over the first time. What could cause this problem?
    Art replied 2 years, 3 months ago 8 Members · 9 Replies
  • 9 Replies
  • Eric
    July 21, 2024 at 8:33 pm
    Series 60 or 8V-92
    July 21, 2024 at 9:22 pm
    Series 60
  • Eric
    July 21, 2024 at 10:38 pm
    R4 starter relay, <$40
    /threaddetails.asp?Category=What%20did%20you%20do%20to%20your%20bus%20today?%3E&ThreadID=13830#106233
    or keyed ignition switch, <$40 from Prevost
    July 21, 2024 at 11:36 pm
    Thanks Don! I will order a new one tomorrow.
    July 22, 2024 at 9:47 am
    I carry one in the bus just in case
    July 22, 2024 at 9:53 am
    Also, could be the 3 position front/off/rear switch above the engine on the side of the electrical box. Again, call PrevostParts.
    July 22, 2024 at 1:23 pm
    The next time it does it get out the tester and verify continuity. My first guess is the rear 3 position switch.
    No sense throwing money at it for parts that are still good.
  • Larry
    July 22, 2024 at 5:23 pm
    The rear start toggle switch in the engine bay gave me issues like this a couple years ago. I replaced mine and never had an issue since.
  • Per
    July 22, 2024 at 8:24 pm
    Do the gauges and other lights come to life when you turn the key but the starter does not engage? If so, the key switch is OK.
