Spare tire place where Drawer is(how do remove)
Posted by Art on June 4, 2017 at 5:46 pmTring to remove metal drawer in steer compartment can’t get slides to release ? any ideas
Bill replied 9 years, 4 months ago 5 Members · 5 Replies -
There is a black plastic arm on the inside of channel….put your finger on it and push up or down then pull drawer out. To reinstall line up drawer slide with cabinet slide on both sides then push back in.
There is no levers,, I know what you are talking about and can’t find it
If there is no mechanical stop like a lever or button that needs to be pushed to remove the drawer just try pulling it hard, equally on both sides. Some I have had did not have a mechanical stop but some type of friction travel limiter.
That style goes back a few years. A shim needs to be inserted in-between both slide pieces. Stretching the two pieces apart when you extend it fully 100%. I believe it’s notched half moon making the stop.
I tried to do mine and I think I figured out that at the end of the slide there is a small piece of the slide end bent in to the track so that the sliding track will stop and not come out.
I didn’t have time to find an old screw driver or something I could bend out the tab and remove the drawer.
Just wanted to clean out from under it.
Will have to get back on that project.
See the bent in tab in your photo, see if you can bend that to the left and see if the slide will come out.
