  • SOS Lost power to the coach…
    Posted by Dorel on March 10, 2022 at 10:27 pm
    Just arrived this evening at Pelican Lake for the weekend to find a powerless coach…
    Left here on Feb 21, all good, no issues…
    Facts:
    – inverters not On – all panels / switches power are off
    – reset Main and Aux power switches – no luck
    – checked and reset power from pedestal thru power surge unit – all good
    – reset transfer switch- both lights on – did not hear inverters start
    – reset emergency switches – did not hear inverters start
    – reset inverters fuses – no luck
    – generator was on auto start if power failure to maintain coach power, but failed I believe due to other issue
    Any suggestions? Is hot here, we will sleep on the beach chairs tonight…
    Another issue…started the engine… the 2 belts over the compressor are not turning, all others are ok…any connection between the coach power and this? It should not be…
    We are here for only couple days, any fixing suggestions are appreciated!
    Thank you…not going to sleep soon…waiting for suggestions…seven three four three six five 3000…
    Raymond replied 4 years, 8 months ago 9 Members · 9 Replies
  • 9 Replies
  • Bernard
    March 11, 2022 at 8:26 am
    If your house battery’s are dead you will have to get power back in them before your inverters will come back on.
    March 11, 2022 at 9:20 am
    I assume batteries are dead…we had 2 AC on and the fridge…but had the auto Gen ON also, wondering what happen there, plugged on constant 50 amps with Progressive surge on.
    I will need to get now the batteries individually charged to minimum to have the inverters on, is it possible the transfer switch went bad?
    I did a complete reset on the coach, no luck…
    There is no power in the coach at all…
    Engine runs ok.
  • Raymond
    March 11, 2022 at 9:29 am
    Do you have a meter to check your battery Voltages?
  • Frank
    March 11, 2022 at 9:46 am
    Dorel,
    If the engine starts the alternator will charge the house to get the inverters going. You should have Xantrex if so go to the remotes and move the cursor to ON (a line under on) they will come back on line.
    Need more info to figure whats going on. Do you have the shore power breaker in the basement to let power in?
    I just read your post again. What compressor belts are not turning? You sure it’s not your big alternator ?
    Later
    bv
    March 11, 2022 at 10:10 am
    Thank you all…
    Bernie,
    1st- engine- last night was late, engine belts were loose…the 3 were running but the 2 over the compressor were not…restarted this morning, managed to keep the belts on and ran the engine for one hour or so…
    2nd- none of the lights in the rear panel are on nor the Xantrex remotes…so can’t do anything there…the transfer switch in the 2nd bay is on ….
    There is no power in the in the coach at all, not even on the dash monitor.
    THANK YOU very much for calling, appreciate your help!
    March 11, 2022 at 10:17 am
    Hi Dorel,
    Have you tried calling Jeff – RV Mobile Medic who is also an owner at Pelican Lake (941) 538-8256.
    2005 XL Thompson Coach
    March 11, 2022 at 11:15 am
    Dorel
    Your going to have to jump the solenoid in the rear engine bay curbside to excite the inverters. The coach batteries got too depleted.
    I can walk you thru it or Marathon Tech can.
    Later
    bv
    March 11, 2022 at 1:04 pm
    Check ATS automatic transfer switch pull cover off and with a meter see if shore power is making to coach, Do you have a surge protector? if so check power going through, If batteries are dead your inverters would be dead also
    March 11, 2022 at 5:05 pm
    Update…
    Thank you all for your suggestions, all good stuff…been busy all day until about 4pm…issue resolved thanks to Bernie that followed up with me and Marathon Service Dept at the Marathon HQ.
    Again, Marathon Service Tech proved themselves as the best customer support in the coach conversions.
    Electrical Tech Lead Terry took the time to guide me through troubleshooting and fixing the issue with patience and professionalism from start to finish.
    THANK YOU!
    Now to the issue at hand…as described in the initial post, I lost power to the coach completely, no inverters, no gen, nothing…
    Through Marathon troubleshooting procedure, we were able to “resuscitate” the coach / inverters, get them to start charging the batteries and then root cause the issue…couple of the wires connected to the transfer switch breaker box were damaged / burned out, probably due to aging…replaced the two wires and we were back in business…coach all powered up and getting cooled…
    Terry from Marathon Coach was “with me” the entire troubleshooting time making sure is done right the first time…
    All forum suggestions were considered and in line with Marathon troubleshooting procedure.
    Calling Jeff at Pelican was on my speed dial since 6am today, but wanted to give Marathon a chance…thank you!
    THANK YOU Bernie and Terry at Marathon Coach, Coburn, Oregon…
    Issue RESOLVED, thank you all!
    Best regards,
    Dorel
