SMC Valve
I seem to have air leaking thru my SMC Valve which controls my air bed. Both ports which have plugs in them leak when I put my bed up and then down. Plus, very small leaks are coming from these two ports when their is air over 40psi put thru the regulator.
Other than replacing the SMC Valve, could the two air cylinder’s under the bed have bad O-Rings which is causing them to leak back into the SMC Valve?
Also, what psi do you have your air bed and pocket doors set at? I know the gen bags are 25psi.
