  • Side mirrors
    Posted by Art on February 10, 2017 at 2:56 pm
    Just bought a 1997 Prevost Royale and the side mirrors are not moving with the switch and the owner said he changed mirrors and did not reconnect power to mirrors I wired mirrors with wire to coach followed color 8 wires connect and does not work right thats when I called old owner and he said it had Ramco mirrors on it before what do I need to connect new switches and harness?
    Walter replied 9 years, 9 months ago 4 Members · 3 Replies
    February 10, 2017 at 7:49 pm
    I’m not clear on what mirrors you have now, are they Ramco, or did the previous owner put something else on in place Ramco.
  • Walter
    February 10, 2017 at 10:41 pm
    Today I learned alot about Mirrors Prevost came with Ramco mirrors and prevous owner put on Velvac Model # 2030 bench tested mirror and it was good installed it and it was all goffy so I called old owner and he told me the story now it makes sense so I talked to a very helpful teck from Velvac and I ordered 2 switches and 2 wire harneses and a good wire schematic on new install so when they arrive I will install
  • Richard
    February 11, 2017 at 5:27 am
    Obviously another Crapco Mirror satisfied customer.
    It is sad that as expensive as our coaches are that Prevost cannot get their vendor to add one more step to the plating process to make the lousy finish last, or fix the mirror vibration without us having to wedge foam rubber into the mirror to stop the shaking. Doing that makes the electric adjustment feature useless so they might just as well eliminate the two adjustment switches.
