  • Shore power cord danger
    Posted by George on December 12, 2020 at 9:41 pm
    Today i decided to open my shore power plug as one of the blades seemed to be loose compared to the other prongs in the plug.
    When I removed the cover to the plug I attempted to test the blades and connections. The blade that was seemingly loose let loose of the wire as i pulled on it.
    The other blades took two or more turns on the connection screw to tighten them.
    Inadequate tension on electrical connections creates resistance which generates heat, which leads to electrical fires.
    May not be a serious issue if connected to a campsite plug, but if connected to your personal receptacle as in my case is inside my warehouse could lead to a fire inside building and serious loss of property.
    Additionally this has detriment on power supplied to coach from receptacle which cord is plugged into.
    Ed replied 5 years, 11 months ago 3 Members · 2 Replies
    December 13, 2020 at 10:42 am
    Good catch!
  • Ed
    December 13, 2020 at 11:31 am
    It does not matter if it is AC or DC….your connections at; battery, plugs (110&220) Outlets, components and equipment must be tightened per manufacturing or industry recommendation. Grounds especially. Or you could end up with a bad experience such as fire or arcing that could lead to explosion or fire if there are vapors in the explosive area.
