Shade Issue
Posted by Tommy on November 13, 2015 at 10:38 pmShades in dinette and salon areas will not raise nor lower. Tried both crestron and control panel without success. Open to suggestions. Thanks.
Peter replied 10 years, 11 months ago 7 Members · 6 Replies -
Check the GFCI on the outlets for the front of the coach. Is the breaker for the front of the coach on?
Agree with GFI, and you may find the GFI outlet under the kitchen cabinents, or in the toilet area.
I’ve reset the two GFCIs, one in the galley the other in the head, without success. The red indicator light on the small individual panel is nit own. Both the Crestron and the rear switch panel in the bedroom function. Are there any fuse locsted elsewhere for the front shades? Thanks.
Tommy I am not at the bus or I could look it up on the electrical paper so maybe Jeff can jump in here to help
On my previous ’03 Liberty I had the same failure. It turned out to be a failed power supply for the salon shades. It was located under the DS sofa. The original part was NLA, but a comparable replacement was esily sourced at Grainger. You might check that power supply.
