Series 60 coolant 2 Thermostats
Posted by Art on February 22, 2021 at 9:14 pmGoing to change coolant hoses so I want to replace both Thermostats any Detroit part numbers??
George replied 5 years, 8 months ago 9 Members · 10 Replies -
Art I replaced mine on our last coach part numbers were on the valve cover. I also went down 10 degrees cooler, but would not recommend that ,found motor ran cooler but more fuel according to Silverleaf ,so I replaced with recommended 190 degree stats.I believe computer dumped more fuel to raise temperature once I removed cooler stats back up towards 7 mpg .I would stay with Detroit parts not after market stuff.
All I see on valve cover is Thermostat 0358 ? but digging I found OEM 23532436 it is a 190 degree Thermostat
Art I was able to find the stats I used they were Gates part number 33599 190 degrees no problem with installing.
Art, Please take and post photos of the t-stat replacement 🙂
I did them on an old Cummins c8.3, yet don’t even know where they are located on the Series 60
Are the two thermostats easy to find? Get at? Replace?
I wonder how many people on the Forum know the Detroit or Volvo engines had two thermostats.
LOCATION of thermostats when you open engine doors they are located on left side of motor. You will have to look around turbo pipes,just in front of turbo to the right. Memory housing is fairly heavy and I accessed it by going over valve cover, also replaced sending unit when I was back there.
I called a local Frightlinner dealer and they use Detroit engines and ordered 2 thermostats Detroit #23532436 190 degree $40 per comes with seals and also housing gasket Detroit #23525151 $7, also ordered bypass hoses that go from water pump to thermostat housing 2 of them Detroit # 8929875 1.75 ID x 3.25 long.
Art I can’t recall but I also replaced a sending unit either in housing or right next to it in head ,it communicated with DDEc believe water temperature sender . Good luck
I do see that it looks like it goes the mechanical temp gauge
