Secondary Tank (only) Cycles Excessively
New mystery… While cruising down the interstate (and not braking) noticed only my secondary air tank cycles excessively.
Only the secondary drops from 130PSI to 120PSI then goes back up to 130psi, and repeats, every five or so minutes. Primary and aux tanks remain steady at 130psi.
All three tanks hold pretty steady when parked with engine off.
The bus passes the DOT brake test.
I replaced, as purely preventative maintenance, the Haldex air dryer almost one year ago and its integral governor cuts out at +/- 130psi
About 2 months ago, I replaced R12’s, R14, SR7 valve, PR4 shuttle valve, all brake chambers and hoses; and about two weeks ago, the secondary tanks check valve. I did blow into the check valve and it worked with human air pressure.
Hope someone might have an idea. Thank you, Jeff
