  • RV PARK POWER SUPPLY TESTER
    Posted by Archived on February 18, 2012 at 11:22 am
    I want what the title says, a handheld tester I can plug in to rv park pedastel before hooking up to check function. I know I can use a multi-tester if I do several checks but I want something more user-friendly. I found a website for a product called ’50 Amp Powerpal” which is exactly what I want, but they have been unavailable for several months. Anybody out there can help?
    gary replied 14 years, 7 months ago 4 Members · 12 Replies
  • 12 Replies
    February 18, 2012 at 3:05 pm
    http://tweetys.com/50-amp-portable-surge-protector-polarity-tester.aspx
    This is the surge protector I use and before I plug my power cord in I plug this in. If the 4 lights are lit all is well. If not it shows the problem. Word of caution…….the lights are hard to see in bright sunlight.
  • gary
    February 18, 2012 at 9:32 pm
    http://wwww.nyrv.us/electric/Pg/tester_50amp.htm
    I built one of these and it works well. Cheap for parts.
    February 19, 2012 at 6:51 am
    I use the same surge protector that Jon has and it’s worked well for many years. Seems like the guys that bought the more expensive version with digital displays have had a bunch of problems and some are on their 2nd and 3rd replacement.
  • Tom
    February 19, 2012 at 7:53 pm
    If it’s good enough for Jon….thanks.
  • gary
    February 20, 2012 at 6:41 am
    Looks like a good unit for the price. Any problems if there is a ground fault breakers at the post?
    Thanks,
    February 20, 2012 at 8:55 am
    Some coaches trip GFCI receptacles, some will not. It depends on how the converter handles the connection to shore power and establishes a ground connection prior to the transfer switch letting shore power into the bus.
    The surge protector has no affect.
    February 20, 2012 at 10:07 am
    I’ve ordered one. Question: Will this also function as a check/surge protector on 30 amp hookups if I come from the pedestal with a male 30 to female 50 into this unit?
    February 20, 2012 at 12:46 pm
    Pure conjecture…………I would assume the surge protector functions as a protector based on the power into it, and not how the power is drawn downstream. Good question for the manufacturer.
    February 20, 2012 at 12:52 pm
    So what do you use for polarity checking/surge protection on 30 amp hookups.?
    I’ve never had an issue until my last trip into an OLD park with 30 only and I had a couple screwy things happen.
    February 20, 2012 at 1:34 pm
    I cannot remember the last time I only had 30 amp power available. If I cannot get a campground with 50 amps I just dry camp and run the generator. I guess that makes me an energy snob.
  • gary
    February 20, 2012 at 2:08 pm
    HA! I finally stumped Jon!
  • George
    February 20, 2012 at 5:42 pm
    Good for you Joel, but write it down for future reference, because he’ll forget and then accuse you of making stuff up!
