  • RV 1 Fuel Additive
    Posted by Ken on April 21, 2015 at 9:31 am
    I purchased some of the RV 1
    fuel additive at the Oyster Fest Rally and did as Ken suggested if you weren’t
    going to get your fuel polished. I doubled the recommended amount of additive, started the engine and generator,
    let them both run for several minutes, shut both down and let everything set for about
    12 hours before I left the next morning.
    My trip down from Exit 67 on TN
    840 then I-65 south to just after Birmingham was windy, mostly raining and we
    got caught in Birmingham rush hour, about a 20 min delay. I didn’t use the
    cruise very much because of the weather and traffic. I was really trying to drive for fuel mileage.
    I was trying to maintain 67/68 MPH letting it pick up a little extra speed on
    the down hills and pull down a little slower on the up hills. We stopped at
    Peach Park exit 205 for ice cream like always. By then the wind had stopped,
    the rain had stopped, the traffic had thinned out and it was beginning to get
    dark. I didn’t write it down but I think
    my Pro Driver showed 8.8 MPG average for the trip at that point. After I got
    back on 65 I set the cruise on 67 and it pretty much stayed there until exit 37. When
    we got setup at our site I wrote all the related Pro Driver information
    down.
    I want to state that I am not
    100% sure my Pro Driver’s calculated MPG is correct, but if it’s wrong it’s consistently
    wrong. My fuel gauge is reasonably accurate. The tank holds 220 gallons and
    when the gauge shows ½ tank it takes a little over 100 gallons to fill it up
    and when the gauge shows 1/4 tank it will take about 160 gallons to fill it. My
    gauge was slightly under full when I left and about a needle under the ½ mark
    when I checked it the next morning after returning home. So about 950 miles on
    100 to 110 gallons of fuel if I was going to guess using the fuel gauge.
    These are the results for the trip to Bella Terra
    Trip Average
    Total miles 469 (my GPS
    showed 475)
    Average speed 60.2
    Average fuel economy 9.2 MPG
    51 gallons of fuel
    On Cruise Control
    200 miles
    9.68 MPG
    20 gallons
    Top Gear (meaning when
    transmission is in the highest gear)
    443 miles
    9.56 MPG
    46 gallons
    I cleared all the info in my Pro
    Driver before leaving Bella Terra. We stopped at Peach Park exit 205 as usual
    for lunch and ice cream.
    I wrote down the Pro Driver
    info when we stopped because all driving conditions from exit 205 to Bella
    terra and from Bella Terra back to exit 205 were the same. Cruise speed, wind temperature,
    etc. I set the cruise on 67 when we got on I 65 exit 37 it pretty much stayed
    set until exit 205.
    Results from Bella Terra to exit 205
    Trip Average
    Total miles 215
    Average speed 59.9
    Average fuel economy 9.45 MPG
    23 gallons of fuel
    On Cruise Control
    155 miles
    10.13 MPG
    15.4 gallons
    Top Gear
    195 miles
    10.2 MPG
    10.2 gallons
    The results from the Pro Driver
    when we reached home. We stopped 2 miles before our exit and unhooked, it’s
    easier.
    Trip Average
    Total miles 467
    Average speed 63.3
    Average fuel economy 9.76 MPG
    47.88 gallons of fuel
    On Cruise Control
    388 miles
    10.11 MPG
    38.38 gallons
    Top Gear
    446 miles
    10.17 MPG
    43.88 gallons
    What does all this mean?? Not
    much just based on one trip but it does look encouraging. Just running the numbers
    in my head it’s about a 5% increase in fuel mileage which about cancels out the
    cost of the treatment.
    I think the results from the “On Cruise” readings,
    trip down and from Bella Terra back to exit 205 are the most comparable. They were
    both captured under extremely similar conditions
    I think some other members
    purchased some of the magic tonic and I would like to know if anyone else has
    any early results. Here’s a couple shots about 80 miles from home.
    Glenn replied 11 years, 6 months ago 13 Members · 15 Replies
  • 15 Replies
  • Rudy
    April 21, 2015 at 10:36 am
    Where do we up this stuff? I’d give it a shot in my old two stroke. I average around 6.3 normally. Have gotten as high as 8.3 average when keeping speed around 62. Pretty good averages already for an 8V92, but I’m always up for anything that is an improvement.
    April 21, 2015 at 4:00 pm
    Parliament Coach, they are an advertiser on this site and
    good folks to do business with. The retail price for the additive is $132
    dollars per gallon. It’s available at a discount to PC members, $100 dollars
    per gallon. Normally 1 ounce per 10 gallons of fuel.
    Dale let me know about those salvage coaches after you get
    what you need. I’m betting one them is that burned red one that was Ebay
    several times. Belongs to the dealer in Oregon.
    Let us all know how the additive works for you.
    Prevost Prevost
    Parliament Motor Coach Corporation
    Ken Robertson 888-571-5755
    4455 Ulmerton Road Clearwater, FL 33762
    ken@parliamentcoach.com
    http://www.parliamentmotorcoach.com
    Since 1990, the name Parliament has stood for quality and service in the RV industry. Manufactured with pride and focused on serviceability, the Parliament Prevost Conversion sets the standard in our industry for reliability and ease of use. Today, under new ownership, Parliament Motor Coach continues to provide unparalleled service to coach owners from around the country. Whether needing routine service work, collision repair and paint, remodeling, or upgrading any coach systems, RV owners know that they will receive the finest of everything at Parliament Motor Coach.
    Under the new ownership of Ken Robertson and Rick May, with over 70 years of combined experience in the RV industry, Parliament Motor Coach is looking forward to leading the Prevost Conversion Industry into the next generation of Luxury Coaches. Production will begin soon on the most innovative, exciting, and yet user friendly coaches our industry has ever seen!
    General Manager Ken Robertson and Service Manager Rick May, and their staff of industry veterans have hundreds of years of experience making sure that your expectations aren’t just met, but exceeded.
    April 21, 2015 at 4:43 pm
    Home in Baytown with a little over 500 miles on RV 1. Ran 60 mph at 1280 rpm and got a little over 9 mpg. I usually run 65 mph at 1400 rpm and get 7.9 mpg. So I am pleased as my mech urges me to keep good additives for the injectors.
    I have a stuborn miss at idle, just gives a spitt or two from time to time. Runs great, pulls great but a spit when idling the Cummins M11E set at 400 hp. So the RV 1 did not cure the spit yet.
  • Andre
    April 22, 2015 at 6:20 am
    As long as Ken started this thread I will add to it because I am doing a full blown test on RV-1 because I have a base of perfromance data.
    Ken has been “massaging” my coach so the benchmark for my reporting of the results of RV-1 will be the miles I have driven since my coach was last modified and my reporting will be based on miles driven since the fuel polishing and use of RV-1 starting with the refueling just north of Bella Terra at the Love’s at highway 59 and I-10.
    Since my coach engine was last modified I want 6841 miles, refueled 9 times, added 1095.564 gallons for a fuel mileage average of 6.24MPG. That is the benchmark I will use for comparison purposes. What I cannot do is provide any subjective information about improved performance of my generator or Webasto. They both seem to run fine with no smoking or rough perfromance.
    I have an odd situation that I cannot explain, but I will post it here just as a piece of information. The last 2019 miles have produced a much better fuel economy and I have no explaination. I refueled three times and the mileage based on 307.143 gallons added works out to 6.57 MPG. The jump in mileage leaps out at me because my coach up until the final three times I have refueled I was reasonably consistent with respect to mileage at around the 6.2 value. For purposes of evaluating RV-1 however I will use the 6.24 MPG value.
    For purposes of consistency I use cruise control to the maximum extent. Whenever I can, regardless of the speed limit on the highway, from 55 to 70 plus I drive at 1500 RPM which gives me a speed of 62 MPH based on both the GPS and the speedometer. My MPG as shown on the message center is skewed to the high side and will be corrected to be more accurate, but for this test of RV-1 it will remain as it has been since my last engine modifications. Just as a bit of information it had been reporting 6.7 MPG prior to the reset after fuel polishing, after fuel polishing it has shown 6.8 but I am not attaching any significance to the added .1 MPG right now.
  • Jim
    April 22, 2015 at 7:39 am
    I thought of something else I wanted to add to this discussion.
    During the fuel seminar Saturday at Bella Terra “Fuel Specialist Ken” mentioned
    diesel fuel being dead in 6 weeks from time of refining, I think. I never had a
    chance to ask exactly what dead fuel meant. I filled up my coach last November
    or so. Maybe that’s why I saw a noticeable increase in mileage, also I had double
    the amount of additive in my fuel. That could also contribute to my increased MPG.
    I don’t use my coach very much, my crazy employer expects me work 40 hours a week.
    So it’s going be a long time for me to have any meaningful information. Thanks to
    Jon’s OCDC record keeping his results should be accurate.
    Ken
    April 22, 2015 at 1:01 pm
    Fuel News
    STORAGE LIFE
    Under normal storage conditions diesel fuel can be expected to stay in a useable condition
    for:
    • 12 months or longer at an ambient of 20oC. ……… Little more help for the PC Tenn. members = 68 deg.
    • 6-12 months at an ambient temperature higher than 30oC. ……….. More help even for guys in GA. =86 deg
      As diesel gets older a fine sediment and gum forms in the diesel brought about by the
      reaction of diesel components with oxygen from the air. The fine sediment and gum will
      block fuel filters, leading to fuel starvation and the engine stopping. Frequent filter changes
      are then required to keep the engine going. The gums and sediments do not burn in the
      engine very well and can lead to carbon and soot deposits on injectors and other combustion
      surfaces.
  • Bryan
    April 22, 2015 at 9:15 pm
    What software,interface are you running on your tablet? The photo facinates me, I’m an info freak.
  • Dean
    April 22, 2015 at 9:55 pm
    Silverleaf, a great product and great support if you have questions.
    Silverleaf
    Ken
    Edit: Last night I remembered we have a PC member has designed a similar device and software for Apple products. It also gets high marks. Someone jump in and tell us who that is, I don’t remeber.
    April 23, 2015 at 12:46 am
    Is anyone else impressed that Ken spins his engine at less than 1400 rpm to acheive 68MPH? Kudos, Ken. That is an awesome setup. No wonder you are at 9+ even without the magic juice.
    p.s.: Be careful with the 70 MPH selfies. (Check out your reflection in the Silverleaf display.)
  • Reagan
    April 23, 2015 at 6:58 am
    Ken has installed a 14 liter engine in his coach along with a 10 speed transmission so he not only is able to extract some impressive mileage, I would not want to try to drag race him.
    FWIW John Klopp had a 97 Royal with a 12.7L engine, unmodified, with the 6 speed Allison and he was able to get 9 MPG with careful driving. I believe he limited his speed to 65 and he did not tow.
    Part of the reason for good mileage is Ken and John’s coaches are relatively light compared to the later model 45 foot coaches.
    April 23, 2015 at 7:41 am
    Bryan I saw that reflection and since most of my face was
    blocked by the camera I didn’t think it would scare anyone too bad.
    Jon is correct. By today’s standards my coach is light, a
    little under 40,000. For that trip I was towing our ½ ton extended cab truck,
    about 5,000 pounds.
    I got lucky on the differential ratio. It had a 3:36 from
    the factory and I thought it worked really well with 8V92 / 750 Allison. The Eaton
    Ultrashift has a ratio of .74 for 10 th
    gear. Which I knew would put me at about 1400 RPM at 70 MPH. Just in case anyone
    is curious the top gear in the Allison is .64 which means you would need a 4:125
    differential to get similar results. I think most Prevosts with the 6 Speed
    Allison have 4:30 or 4:50 rears. I would like to try the new Allison TC10. From
    what I can find it’s quite a bit larger than the Eaton, if that’s correct it
    won’t fit in my coach, the Eaton almost didn’t fit.
    Ken
    April 23, 2015 at 10:22 am
    Jon is correct about the MPG on the coach previously owned by John Klopp, I purchased that coach last year and I’m consistently getting high 8’s low 9’s @ 65mph. On one trip last year I averaged 10.3, WOW!!! Coming from towing a 34 ft. Airstream with a Super Duty 6.4 and only getting around 12 mpgs, just amazes me..
    April 23, 2015 at 1:03 pm
    Ken: Very impressive slideshow and video covering your re-engine/trans project. What a task to take on. Is that the same DD engine our late 90’s and early 2000’s coaches? If not, what kind of hp/torque do you have?
    Anyone who hasn’t taken the link in Ken’s signature and see his project should!
    April 23, 2015 at 1:57 pm
    Dick it’s similar to the earlier 12.7s but there are several
    differences. The main ones are, it had EGR, it’s a larger displacement 14
    liters, it has a different gear train that drives the camshaft(known as Compact
    Valve Train) and different injectors. The original HP/ torque was 515/1650, with
    my modifications I would guess 600/1800. That’s just a guess, it’ll take a dyno
    to find out for sure. I think 2005 is when the 14 liter started, it changed
    very much in 2007 when DPF filters were added. Although the basic block and
    head were the about same the engine controls and injection system was very different
    and in about 2010 the Mercedes engine know as DD13, DD15 or DD16 was introduced which
    require diesel exhaust fluid. There was
    a very limited number of 575HP 14 liters with the old style valve train and no mechanical emission controls manufactured in 2000 or 2001. There were also a few DDEC IV compact valve train
    12.7s with EGR produced a year or so before the DDEC V 14 liters were introduced.
    And thanks for the compliments.
    Ken
  • Glenn
    April 23, 2015 at 3:29 pm
    Non EGR 12.7s should be able to get 8 mpg pretty easy with low rolling resistance tires like the XZA’s, keeping speed around 60 mph and using synthetic fluids does not hurt either.
    This ofcourse assumes summer fuel, good weather, easy terrain etc.
    Also, my 02, and I think all other 6 speed Allison coaches have a 4:56 rear end. No doubt that these busses would get better mpg and climb better if we had more gears to choose from.
