Roof paint and sealer
Posted by James on May 29, 2022 at 4:13 pmHi
i am new owner of 98 royal 45′.Wondering what is best paint or sealer to
paint top of unit.I have caulking to reseal existing penetrations. Is
there best brand to buy.Also looking for another owner of 98 royal to ask a few questions.
thanks jim
Dick replied 4 years, 5 months ago 11 Members · 13 Replies -
What do you have there now? Is it the factory paint? How much effort do you want to put into it? For example, my roof was badly sun burned, and many of the rivets seemed like they would leak so i decided a full new coat is needed. I removed everything from roof, fully sanded it down with 80 grit to the aluminum base metal, and coated it. I started the project using Bus Kote with beads mixed in on a small area but i didn’t like how abrasive it was. I felt it might be hard to keep it clean. So i went to Home depot and bought a 5 gallon pale of Henry’s tropicool and coated my entire roof with that. It has been over a year and everything is holding up well, the only negative i have with Henry’s is it is very slippery when wet. If you go up on your roof to wash it as I do, i have to be very careful. Other than that it washed off to a pristine white color.
“Temp-Coat 101” five plus yrs ago. No regrets.
98 Royale 45 ft
removed everything
two washes with denatured alcohol
two coats bus Kote primer
4 coats bus Kote 5gals
3lbs ceramic mixed into bus Kote
My roof is down to metal in someplace .Looks like I better do it right and take everything off .Did existing paint come off easy with electric sander?
thanks jim
Would like product that is not slippery to walk on.
Interested on what don put on 5 years ago.Can we talk about procedure to install
jim
James0 or anybody, right click on “lonestarace”, top right hand corner of any of my post. That’s my email, I’ll give you my ph# to call.
Hi mike
how long did it take to sand down paint on roof?
did you use electric sander with 80 grain sand paper
It took me about 4 days to complete the project. I removed all 3 AC units, Vents, Old satellite dish etc. Once I had all the hardware off, I scraped all the old sealant off with a putty knife, then using an orbital sander, and 80 grit discs I sanded it down. Sanding went pretty quick, my roof was in very bad shape. Next step was to clean the roof, i used simple green and water, blew it off with my leaf blower then let it dry. My roof has movement in between the bars that run from drivers side to passenger side and i could see the rivets moving slightly. I was a little concerned that over time the roof coating might break thru and cause a leak path, so i opted to use Eternabond tap for the seams and rivets. There are many that don’t like Eternabond, I like it and have used it on many of my RV roofs. I used Dicor on the edges of the eternabond, then coated Henrys’s over the top. Henry’s doesn’t stick to Eternabond, so that is exposed to the elements. In the picture attached you can see the eternabond going acroos the bus from left to right over each support beam. Every time I wash my roof it gets nice and white like shown in the picture. The other picture is how bad my sealant was after 30 years.
Good job Mike. But..those railings are a bit low!
Jeff and Lindsay
91 Marathon XL -
How did you know that’s where she sits during travel days? I am Kidding, I am Kidding!
