  • Roof air conditioners
    Posted by Eric on July 29, 2014 at 10:49 pm
    1995 Prevost Country Coach: Two of my three roof air conditioners work well, but the third just stopped coming on. I have checked the main breakers that control them and have also checked the breakers next to the inverters. Each air conditioner is controlled by a thermostat and a sunmulon switch in the front. When I activate the switch, I hear a clicking sound in the breaker panel, but the air conditioner does not start. Any suggestions?
    Dick replied 12 years, 3 months ago 4 Members · 4 Replies
    July 30, 2014 at 11:00 am
    The industrial switch in the overhead controls a relay that allows 120v ac power to the air conditioner unit. Relay failure is not uncommon, and may likely be your case. Following all appropriate electrical safety precautions to prevent injury due to electric shock, I would check the relay coil and ensure there is 12vdc control power to the coil, ruling out a dc control circuit problem, then verify 120v ac to the input side of the relay, and out when energized. I suspect the relay contacts are probably burnt up.
  • Alvie
    July 30, 2014 at 12:17 pm
    Thanks for the reply. I don’t know where to find the “industrial switch in the overhead”?
    July 30, 2014 at 2:57 pm
    Eric, I have a 98 CC and my coach does not ues the square lighted Sun Mullion switches to interface with the roof airs. Do I understand yours is different.
    My 3 roof units are wired to a breaker panel in the bedroom on 20 AMP breakers and I don’t know where the thermostat gets its power. I saw where you checked the breakers so like the previous reply check to see if the thermstat is calling for A/C check to see if you are getting 120 V at the unit. Pull down the grill that covers the air filter and you will find a junction box where the 110 V wiring comes in. At least mine is wired this way. Be cautious, hopefully the wires will be hot.
    If you have power to the unit then go to the internet snd check Dometics website to see the drawings for your modle units to see if there is a reset swith or breaker in the unit itself. Assuming you have Dometic brand units.
    My thermostat controlls the three roof units and nothing else.
    Good Luck
    July 30, 2014 at 3:55 pm
    Yes, that is correct. There are three thermostats, but I have three sunmulon switches in the front overhead that turns on each air conditioner. I will check all that has been suggested. Thanks,
    Eric
