  • Ride Height Valve
    Posted by Darrell on July 28, 2021 at 10:45 am
    Hi everyone. I have been working on trying to fix a problem with the bus and the leveling system. I have narrowed it down to the ride height valve on the passenger side of the drive axle. Can anyone tell me what part number the valve is so i can order a replacement? My coach number is 312 a 1995/1996 Liberty 45XL any help will be helpful
    Darrell
    Archived replied 5 years, 3 months ago 3 Members · 3 Replies
  • Darrell
    July 28, 2021 at 12:20 pm
    Call Prevost parts and they will get you an exact match based on your VIN.
    July 28, 2021 at 12:58 pm
    Thank you I will do that
    Darrell
  • Billy
    July 28, 2021 at 4:57 pm
    When you replace the valve please make sure the chassis is fully supported. Any work under a coach requires chassis support, but any suspension work makes it mandatory.
    The valve likely can be changed by removing the forward rear fender liner to access it, but you still are working where you can put your self in a pinch point position. It will be a lot easier with the outer drive wheel removed.
