  • replase driver window H345 left side
    Posted by Wilton on February 25, 2015 at 11:16 am
    We have a 2006 H345 that has a fogged up window on yhe driver side , the one with the electric toll below . Is there any place where a procedure and tools required is shown to get this window out and reinstall a new one.
    I plann to do this myself if i can get a sense of the problems that may be more than i see .
    Alvie replied 11 years, 8 months ago 3 Members · 2 Replies
  • Alvie
    February 25, 2015 at 11:33 am
    Had that same unit and door unit replaced at Parliament. Would not want to myself. Don’t remember it being that expensive (relatively speaking of course) but I will look for the invoice. Geo.
    February 25, 2015 at 1:29 pm
    Wilton,
    The procedure is not complex. A good utility knife to cut the Sikaflex, both around the preimeter on the outside, and around the perimeter parallel to the glass on the inside.
    Extreme care has to be taken to prevent the paint from chipping.
    Once the seal is broken and the old glass removed, the entire area around the window has to be scraped clean.
    When the new glass is ready to install apply a bead of Sikaflex around the perimeter of the surface that is behind and parallel to the glass. Set the glass in place. Then fill the gap between the glass and the bus window frame from the outside. Masking tape is used to protect the paint and glass and minimize the mess. Smooth the bead around the glass.
    When using Sikaflex it works best when it is warm.
    If this is not correct or if there is more to the procedure I hope our resident professionals will correct my procedure.
