  • replace fuel line 98 series 60 XL ll
    Posted by michael on April 22, 2017 at 6:55 pm
    Great news,,, found cause of air in fuel lines… a leaking fuel line…. can I replace myself. Its the line from the rear of engine attached to the check valve.
    June replied 9 years, 6 months ago 3 Members · 2 Replies
    April 22, 2017 at 9:46 pm
    returnline runs inside frame rail passanger side to top of tank located behind condensor. Look upper left of that compartment and you will see access pannel. you can get thru there where that line returns to top of tank. All serviceable from below bus. If it’s not a fitting that you can get to at engine. On your 98 holding clamps are prob frozen. I have done it..I would imagine shop time would be 4 plus hrs minimum. I would replace both if your going to open it up. Jeff can chime in here. I prob misread location. If it is short line from head to check valve go for it. If is the tank side then the above is correct. Bob
  • June
    April 25, 2017 at 7:11 am
    I have replaced my fuel line check valve as it was leaking but it is very hard to reach and I dont think I could have reached it if I hadn’t had my bus on my grease pit. Its a brutal job.
    Gary
