Removing H3 Headlight Housing (Round Lights)
Posted by John on March 22, 2022 at 5:53 pmDoes anyone know how to remove this light housing?
Michael replied 4 years, 7 months ago 7 Members · 8 Replies -
There is a screw hidden in the hole in the middle. Unscrew it and the headlight swings out on a hinge.
While you are there, JD Speaker sells a plug and play LED upgrade for the poor Halogen high beams.
I would be interested in upgrading the high beams. I looked at JW the Speaker website. Lots of choices in th 90mm high beams. Do you recall the number of the one you used?
John, I have the same looking headlights as you, I have an ’06 H Marathon.
one of my low beams stopped working and I am unable to match the bulb to any of the selections on numerous web sites. This stuff become Obsolete in a short time and the consumer is left scratching their head.
only help I have received is ” install a NEW upgrade kit”. Well isn’t that special. -
Its’ the 93 series. Note, this is a high beam only so it needs to be on at the same time as your low beam.
That’s the next thing I need to figure out.
https://www.jwspeaker.com/products/90mm-headlights-model-93/
Hi Larry,
If it’s a ’06 I assume yours are HID. If so you should be able to use standard D2S HID bulbs. I use the Morimoto as I had them in my truck retrofitted and worked well. But you should be able to use other brands D2S like Sylvana or Philips also.
Here is a link: https://www.theretrofitsource.com/d2s-xb-hid-B-D2S?quantity=1
Do you have a picture of your old bulb?
I should have stated in my original post that my lights were converted to LED by the previous owner.
thanks for the info
