  • Removing aux engine oil tank
    Posted by Art on January 19, 2022 at 10:19 am
    Has anyone removed the rear engine auxiliary oil tank, I was thinking of getting rid of that tank that I’ve never used before, I’ve never had to add oil before, when I change oil and refilling oil I drain that 1st into engine then when I’m done I put 1 gallon of fresh oil in it. I think it was intended for bus drivers that drive thousands of miles. Less is better.
    Jon replied 4 years, 10 months ago 6 Members · 5 Replies
    January 19, 2022 at 11:52 am
    yes. Generally, my bus uses about 1 gallon of oil in 10,000 miles which is my oil change interval. Since there is about a gallon between add and full on dipstick, I seldom add oil.
    January 19, 2022 at 7:17 pm
    I removed mine about a month ago, posted pictures in what did you do to your Bus Today.
    January 20, 2022 at 8:06 pm
    I don’t use mine – probably should remove it but haven’t.
    January 21, 2022 at 7:18 am
    Art that tank is a great source for water to enter into engine oil ,friend never monitored and condensation and water in engine oil tossed the tank away.
  • Jon
    January 24, 2022 at 1:36 pm
    I suspected the same condensation problem as one of my oil samples when still using tank came back with water.
