Refrigerator not working
Posted by Bob on February 26, 2022 at 12:00 amRefrigerator warning light came on. Checked inverter and getting a inverter bridge fault. Started generator but it still won’t come on. Any suggestions would be appreciated.
Archived replied 4 years, 7 months ago 7 Members · 11 Replies -
I believe that is an inverter issue. That inverter powers a series of outlets, are they all out?
Other outlets out also. I thought of Plugging it in elsewhere but how do you get to frig plug
On my Bus the plug is behind the fridge. I have to slide the fridge out for access.
It sounds like the way your Bus is wired, your Generator output runs through your inverters?
Marathon my bus not yours designed access to back of refrigerator by taking out the two small cabinets in the toilet area aft of refrigerator.
you have pull refrigerator out.. facing fridge about chest high left side .. plug will be marked refer. you may be able to plug into the washer outlet temporarily
I forgot to mention the ice maker/water line is there .. becareful not break it.
We were able to make it to Nashville by traveling with frig locked and plugging into power at night. I had called Inverter Services while on the road. They verified they had parts and we scheduled an appointment for this morning. They removed our inverter and found two bad boards. Once bench tested and reinstalled everything works great.
Try a reboot on the inverter, Unplug coach from 12v turn off batteries, make sure inverter panel is off then turn on DC volts and then AC volts see what happens
Excellent Bob!
2005 XL Thompson Coach
