  • Recommended Air Pressure Multiplier
    Posted by Cathy & John on October 21, 2014 at 8:12 pm
    On behalf of John . . . someone (Bernie maybe?) recommended an air pressure multiplier to John. Does anyone have any recommendations?
    Thanks!
    Cathy
    Andy replied 12 years ago 3 Members · 3 Replies
    October 22, 2014 at 6:49 am
    A number of owners have equipped their coaches with a multiplier. The stated reason is to provide a higher pressure for those times when it is needed such as to fill tires.
    I have found on those rare occasions when I have needed to inflate a tire or use high air pressure that the engine driven compressor works within a 100 to 120 PSI range so ample air pressure is available when needed as long as I run the engine. My aux compressor is set at a much lower pressure since nothing in the aux system that is used when the engine is off needs anywhere near the pressure the engine driven compressor provides.
    Remember an increase in air pressure downstream from a multiplier comes at the expense of air flow or volume. To get the higher pressure you sacrifice the volume of air flow which I think is inversely proportional to the pressure increase.
    October 23, 2014 at 12:27 pm
    SMC Booster Regulator
    NVBA 1110-T02
    Input 14-140PSI
    Max output 280PSI
    about $300 new, have seen on e-bay used for as low as $30
    October 24, 2014 at 9:15 am
    Thanks, Steve! 🙂
