REAR Cruisair down
Posted by David on April 18, 2015 at 9:36 pmThe rear cruisair is not working ‘ the control panel is blank, button on dash is on , breaker is on,, is there any secerts or something i am missing?
Archived replied 11 years, 1 month ago 5 Members · 5 Replies -
At the risk of stating the obvious it would appear the Cruiseair is not getting power.
I would start at the breaker and verify power, working my way to the various system components. I think you may have a condnesing unit on the bottom behind the entertainment center, a “brain” in the first bay and the evaporator possibly on the passenger side rear wall.
Jeff…….Any quick checks? If the relay is bad I think it is behind and under the electrical panel, correct?
rear air still down any help would be helpful. All breakers are in push the button on the dash to turn on the rear unit and the light comes on on the switch but nothing else, where are those relays you are talking about?
Dave, I think you or any technician is going to start by looking for power at the unit itself. If it does not have power the only solution is to work backwards until the open circuit is found. If it does have power look at the Cruise air controls.
Well we are up and running, what i found was a bad remote breaker, once i received the wire numbers from Marathon the problem was pretty easy . just for your guys info. when yoiu have a wire number with a number like 109m and 109a . M for Main breaker box and A for Aux breaker box
thanks for the input!
