Rear Camera Cover ?
Posted by Larry & Diane on May 18, 2016 at 5:30 pmThe clear cover on our rear camera is no longer clear? Is there an uprage or replacement ?
Thanks… Diane
Tim replied 10 years, 6 months ago 6 Members · 8 Replies -
If it is the Total Vision camera and housing, call them. They are great to work with and will sell you what you need.
Total Vision® Products LLC
Phone: 520-623-0790
625 W. Plata Street
Tucson, Ariz 85705 -
Mark…
It is a Total Vision… I will call them tomorrow.
Thanks so much !!
Cheers, Diane
I called Total Vision this morning and the guy was more than helpful… he is sending me the entire exterior housing and even going to paint the upper black part as he says they dull over time.
Super nice guy & very reasonable… said to call if we have any problems installing it.
Should get it next week.
Thanks again Mark.
Cheers, Diane
How do you know what kind of camera you have? Is it easy to figure that out?
Dick…
Inside the coach the control pad for the camera has it written on mine… says Total Vision. Don’t know if yours would be the same or not ?
The exterior part looks the same on most Prevosts to me.. our older ’98 model H had a door that openned up when activated…. I lik ethis much better.
Hope this helps.
Diane
The did the same for me when I upgraded the camera on the Legendary. Painted the sun shield black, and even glued it to the new cover. Easiest upgrade ever. Newer camera worked much better as well in low light conditions.
Glad you had good luck with them too.
Ours is tied ot the (2nd to the coach) naviation system. Put the trans in reverse and the camera goes on. There is a switch that leads me to believe that I could turn the camera on anytime, but the switch is inoperative. I suspect when the navigation system was upgraded (copyright 2007) it wasn’t hooked up so we have that functionality. I’ll get the ladder out and look in the bedroom for an access door.
