  • Rear camera clean and passenger nozzle replacement
    Posted by Marius on January 26, 2015 at 4:31 pm
    Hello,
    Getting ready to take the coach to Jeff and I have to sort out some things for the trip.
    How does the Rear Camera clean system work ? Is there a pump and a reservoir somewhere ? Can’t find it if there is….When I push the “Camera Clean” button on the dash there is no fluid coming out of the nozzle above the camera and the pump on the windshield washer reservoir is not running …Maybe this is an Air cleaning system only and no fluid ?
    Now the passenger side windshield washer nozzle – how do you get to the back of it to take the nut off and change it ? It looks to be about 6 inches below top of the dash and behind the Webasto heat exchanger. Any trick getting to it without removing everything in front of it ?
    Thanks. Any advice appreciated.
    Mike replied 11 years, 9 months ago 2 Members · 1 Reply
  • 1 Reply
    January 26, 2015 at 6:45 pm
    It’s just air to clear off water drops
