  • Rear camera
    Posted by Darrell on November 18, 2016 at 10:02 am
    hi all, our 1996 Liberty keeps getting dampness in the rear camera housing. I have removed and resealed it but it still collects moisture any ideas?
    Thanks for your help
    Per replied 9 years, 11 months ago 5 Members · 4 Replies
    November 18, 2016 at 11:13 am
    Typically the moisture is condensation from the humidity inside the coach.
    I had that on my 87 and 97 until I cured the problem.
    On both coaches the glass was a round single pane of glass. I cut a round or square second pane. (I cannot remember the real shape) and I put a bead of RTV around the glass in the cover and placed the new second pane there to act like thermopane windows do.
    To drive out any moisture and to create a slight vacuum I used a hair dryer to heat both up before the RTV cured and once they were both hot I wiggled the new piece of glass to insure the seal was a good one.
    When every thing cured and cooled I remounted the cover and even on cold days when we took showers I never got condensation again.
  • Kent
    November 18, 2016 at 11:57 am
    thank you. Sounds like a plan and I will start on it right away
    thanks again
    November 29, 2016 at 7:09 pm
    Very clever Jon!
  • Per
    November 30, 2016 at 1:28 pm
    Move to Arizona?
