  • Radio/Navigation system won’t work
    Posted by Dick on April 28, 2017 at 7:57 pm
    Dash mounted. Suddenly quit working after Cathie cleaned the screen with Windex. Where would I find be the fuses for this likely 12volt device?
    Archived replied 9 years, 6 months ago 4 Members · 3 Replies
    April 29, 2017 at 4:16 am
    That will have a fuse on the back side of the unit itself to start with….
    April 30, 2017 at 7:51 am
    Dick,
    I use some of those micro fiber eye glass fabrics that are handed out at the Doc’s office to wipe the screen clean of dust and lint. I have not found it necessary to use windex or any other liquid, spray on glass cleaners. If, and only if, some clutz has sprayed some libation on the screen while popping the top, I’d suggest not spraying the screen to clean but spraying a little squirt of glass cleaner onto the micro fiber fabric and then spot wiping the fowled portion of the screen.
  • Michael
    April 30, 2017 at 2:22 pm
    my Kenwood will occasionally go blank , there is a small hole in the front that you can put the point of a ball point pen into push and it will reset
