  • R22 STOP LEAK IN CRUISE AIR
    Posted by Jerry on May 5, 2016 at 9:54 am
    Has anyone had any experience using R22 Stop leak in a Cruise Air System? I have a slow leak in one of my units, and have not been able to find the leak. It will last about 3 weeks. A local HVAC guy suggested that, I am not sure I want to try that.
    Corey replied 10 years, 6 months ago 3 Members · 2 Replies
    May 5, 2016 at 10:11 am
    Somewhere along the way cruise airs came with fluorescent dye so you might be able to find the leak that way.I have found that the glands at the high and low pressure valves are subject to leaking,also the hot gas bypass valves at some point were made out of plastic and AAP has advised me to remove them.I would call Johnny at AAP as he is the guru and they have extensive knowledge on cruise airs.
  • Kirby
    May 5, 2016 at 11:07 am
    I’ll check that out, and give Fred at AAP a call. Thanks Jack
