  • Push button entry door combination change
    Posted by steve on December 17, 2016 at 1:18 pm
    I have a 1999 Prevost C.C and need to change the door combination. Jeff is going to change the key door and combination in a few months and says I need a new Modem. Is the Modem the same as the key pad or are they different parts? Is there a way to change the combination by entering a special code? I believe what Jeff says ,however I met a couple people with Prevost , and they claim you just enter a code.Before posting this I’ve tried to get a hold of Jeff to confirm what they are telling me but to no avail on Saturday.He may be out of town. Anyone with experience with this or advice I would appreciate it. Thanks in advance. Steve
    Archived replied 9 years, 10 months ago 6 Members · 6 Replies
  • Charlie
    December 17, 2016 at 1:26 pm
    Steve, the combination is not able to be changed, however you can add a second code for a personal code…..however it does not stop the original code from functioning….
  • Charlie
    December 17, 2016 at 2:02 pm
    Thanks Jeff, Ididn’t think these guys in the park knew what they were talking about.Could not get a hold of you today to verify or I would not have posted. Thanks again
    December 18, 2016 at 9:01 am
    Why would you want to change the original factory code?
    Just add your personal code as Jeff said.
    December 18, 2016 at 9:19 am
    It is possible someone during the history of the coach lost the personal code. Then they started using the master code, which over time may have been learned by others.
    Easy cheap solution is to trade door lock modules with someone who has the same problem. Just don’t post who you will trade with here so the bad guys just follow the code to the next bus.
    December 18, 2016 at 1:42 pm
    Jerry and Gayle. I need to change everything because I got a Divorce 6 months ago and I,m living in the coach fulltime. Need I say more, everything I own is in My coach. Thanks, Steve
    December 18, 2016 at 1:45 pm
    Say no more! I’ve been there and done that.
