  • Purge valve??
    Posted by Art on August 24, 2019 at 11:26 am
    On my power Tech gen I just replaced fuel filters and fuel pump, a while ago replaced small fuel that goes from 1st injector to this purge valve, here is a picture. lower 5/16 hose goes to fuel filter small Gates hose to injector from this valve with knob. What is the knob used for??
    Archived replied 7 years ago 5 Members · 5 Replies
    August 24, 2019 at 1:06 pm
    This is a made up answer.
    I have no clue what the original intent of that knob is, but if there is a fuel interruption such as changing fuel filters, running out of fuel etc. I connect the fuel pump on my generator to a power source, open the valve and let the fuel pump pump fuel.
    I have started the engine with the valve open, but close it as soon as the engine is running.
    I think it opens a path for fuel past the injectors and into the return line.
    But I don’t know for sure.
    August 24, 2019 at 2:28 pm
    I’m not certain of it’s exact purpose either. At some point in time, here on PC I learned that it is to always be cracked open 1/4 to 1/2 turn for normal operation.
    August 24, 2019 at 2:35 pm
    On my Kubota motor I use it to drain air out of the system. If motor doesn’t start after fuel filter changes or sitting to long , crank and open/twist round valve and it will bleed air out to start.
  • Jim
    August 24, 2019 at 4:57 pm
    Once I used it as it seems a number of us do, I close it. but if the generator runs with it open who am I to argue.
    October 27, 2019 at 8:34 pm
    I’m with you Jon, I use it when bleeding the system but close it after that. Mine is always closed during operation without any problem what so ever.
