  • Progressive EMS-HW50C surge protector
    Posted by Art on December 29, 2020 at 1:28 pm
    I installed this Progressive 50 amp EMS a couple of years ago and I really like the remote portion that is mounted in the wet bay easy to see and read. I always like to watch it when I first plug it in to see volts-amps-errors and cycles. Like to see volts and amps during the day with use of higher amp devices AC’s heaters Aqua Hot 120 v portion and the analog gauges in coach are worth less. So I found on the Progressive web site they have a 2nd remote and a switching box, only 1 at a time can work so after I plug in and look at display in wet bay,I switch to 2nd display that I will mount inside coach and then I can monitor the AC power. 1st picture HW50C EMS 2nd picture is my remote display in wet bay 3rd picture is New EMS RDS display and switch box. I will mount switching box next to 1st display in wet bay and then after checking display switch to 2nd. Pretty simple.
    Art replied 5 years, 10 months ago 1 Member · 0 Replies
