  • Problem with Lincoln MKX transmission
    Posted by Jerry on September 30, 2023 at 10:50 am
    After returning home from FMCA in Gillette, WY, we started having issues with the transmission in our 2017 MKX throwing codes. I foolishly let the battery run down along the way from not running the car often enough or long enough at the end of the day. A jump start battery easily restarted the car but the codes came on and no amount of clearing them has stopped that. The stealership in this area was useless simply charging me a “diagnostic fee” to clear the codes, driving it and finding the codes really do come back, and then concluding “something appears to be blocking the torque converter from locking up…..” but offering nothing more than a vague guess of 15 to 25 hours to find out what is wrong if and when they could get around to scheduling tearing the transmission apart!
    Surely, there must be a better way. I could buy and have a rebuilt transmission installed for less than that. Any suggestions? Have any of you experienced anything like this with these Lincoln/Ford Edge transmissions? Any recommendation as to where to buy a remanufactured unit if that is what it takes?
    Jerry
    Clay replied 3 years ago 2 Members · 1 Reply
  • 1 Reply
  • Clay
    September 30, 2023 at 12:32 pm
    Austin Hicks (GM/Partner) at Olympia Luxury Motorcoach in Murfreesboro, TN installed a battery cutoff switch in the engine compartment when installing the baseplate for our Blue Ox system. We have never experienced any transmission codes, battery problems or towing issues in the two + years since this work was done. Highly recommend.
    FYI – we’ve traveled cross-country (coast to coast) four times and nearly 20K miles without issue.
