  • Pro Driver??
    Posted by Art on April 8, 2018 at 10:24 am
    I was reading some old post about reading codes, Is this 1st pic a Pro Driver and how does it work?? I installed the scan Gauge can you get codes with this?? I don’t have any info on Detroit controller.
    Greg replied 8 years, 7 months ago 9 Members · 10 Replies
  • 10 Replies
  • Dan
    April 8, 2018 at 10:46 am
    A ten second search on Google brought up the manual which should answer all your questions.
    https://ddcsn-ddc.freightliner.com/cps/rde/xbcr/ddcsn/user_manual_6SE703.pdf
    April 8, 2018 at 11:10 am
    I say the same thing but look at picture it’s different its either early pro driver or some thing different?? I’ve looked high & Low on Internet and can’t anything on this unit check out picture> found a used one and it said it was a part 23515448? It is a Pro Driver when I push menu display comes on the it ask for driver ID:
  • needtocamp
    April 8, 2018 at 8:45 pm
    Art, I looked long and hard for the correct ProDriver manual a while back and came up empty? The one Jon posted is OK and better than nothing.
    You might go to or call your local Detroit dealer and see if they are of any help?
    The ProDriver in my bus works great, last along time. It gives good info about:(a) time driven; (b) distance; (c) fuel burn(gals); (d) MPG; etc
  • Deleted User
    Deleted User
    April 9, 2018 at 4:32 pm
    Art and group
    I will upload the pdf for the old Pro Drive like mine.
    Jonathan Fine
    96/97 Royale #201
  • Per
    April 9, 2018 at 5:09 pm
    I also have the older version, but even worse than not having a manual, a previous owner disconnected it somehow and I haven’t figured out where it was disconnected. Probably the user manual says how to use it, but I sure would like to find some wiring schematic for it someday.
    Jonathan, if you have trouble uploading to the forum, maybe you could send me an email with the pdf attached.
  • Harry
    April 9, 2018 at 5:34 pm
    I have the original Pro Driver User manual from the 94 along with the reference card. When she went off to salvage I took all of the manuals out. Art if you’re interested, you are more than welcome to it.
  • Deleted User
    Deleted User
    April 9, 2018 at 11:47 pm
    Yes I would be interested in it I love info
    April 10, 2018 at 8:09 am
    This was on a Facebook page.
    Pro Driver Manual
    April 10, 2018 at 8:42 am
    I saw that also Tom, after I posted, exactly the same version I have.
    Art, shoot me an email with your address if you still want the manual.
    April 10, 2018 at 10:15 am
    Yes I did send you info last night, Did you get it ? to: dansyl159@gmail.com ?? Thanks’
