  • Pro Driver TPS Alarm
    Posted by Archived on July 3, 2012 at 9:11 am
    Every once in a while I’ll get a warning on my Pro Driver that states the TPC condition as low. What’s a TPC? It only last a couple seconds and it clears. So, it currently isn’t affecting the operation and it’s done it since I’ve owned the coach. This is on a 98 coach.
    Gil J
    99 Country Coach
    needtocamp replied 14 years, 5 months ago 3 Members · 3 Replies
    July 3, 2012 at 11:25 am
    I Couldn’t find anything for TPC. TPS is Throttle Position Sensor. It’s on the throttle pedal, usually easy to replace.
    Ken
    Here’s a link the trouble shooting manual for DDEC II, III and IV http://www.mediafire.com/?1yu93hn8k9zjk
  • needtocamp
    July 3, 2012 at 2:12 pm
    I agree with Ken in that it is likely the TPS.
    While it is possible for a TPS to fail, one thing to check is the connector which might be the problem.
    I think it is a 4 pin connector that you can access from behind the front bumper and it may be clamped to the roof of the area behind the bumper. Separate and join the two halves a few times in case there migh be some corrosion or a bad contact.. That area behind the bumper can get some moisture in it when running in the rain.
  • Glenn
    July 4, 2012 at 5:37 pm
    Thanks guys! I’ll give that a try.
