Prevost XL CC Interior LED upgrade
Posted by David on July 17, 2020 at 7:06 pmI noticed all the posts on this subject are ancient, so figured Id add an updated one. Replacing all 29 LED ceiling lights on my CC with new 12v LED. They are $9.16 each on amazon in packs of 6. https://www.amazon.com/gp/product/B089PYN3G5/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
If anyone wants my old brass/gold CC housings, you can have them. I swapped in LED bulbs but thought it looked cheap.
Jerry replied 4 years, 3 months ago 8 Members · 10 Replies -
Nice. Would like to do the same with my coach. Is the cover included or did you have to purchase separately?
Ron
1984 96" with 8V92TA
(remodeled Liberty Coach)
Greenwood, MO -
Comes all as one piece. Super easy to install, spring loaded clips actually more durable than the factory lights. Just order yourself an assortment of 14-16 and 10-12 gauge butt caps so you only have to pinch once per wire instead of twice.
Looks like those are only available as 12 volt?
Be careful pulling the existing lights out. They are usually held in place using two devices from mousetraps that utilize a spring from a bear trap.
The spring got me 3 times. I only cursed the first time. Here it is complete, pardon the rest of the mess.
“Be careful pulling the existing lights out. They are usually held in place using two devices from mousetraps that utilize a spring from a bear trap”
Dick: how do you know this? Did a friend tell you? LOL
Chuck – been there done that
Chuck: It was an OH SHIT! WTF! OMG! moment that lasted about three minutes. I learned very quickly there was a safe and a not so safe way to grab them. The trick is determining where the danger is. I’ve also gotten a finger stuck between the fixture and the ceiling on the re-install. That isn’t quite as bad.
Thanks for the post. I have 6 on the way to finishing replacing the ones I could not find fixtures for. Should be here on Monday!
Leesburg, FL -
Dick:
You got me laughing so hard I am almost crying. It’s only so funny because I have been there more than once. Sometimes I am a slow learner, but the pain cures that.
Chuck
Just did this exact update to my 98 CC.
If you are still around, many thanks, again, to daschae.
Apparently with this dimmer. We have multiple circuits so, it this worked, it would have to be installed in each circuit somewhere. None of ours are on dimmers and we have not found a dimmer to be necessary.
