  • Pressure Pro Tire indicator light
    Posted by June on August 14, 2016 at 11:37 pm
    Just pulled in to Rapid City SD, and 4 of the tire location lights are lit on the monitor. Checked air pressure,temp all ok. No beeping noise. Only when you remove the sensor. Any help is appreciated.
    Donald
    Fred F. replied 10 years, 3 months ago 3 Members · 2 Replies
    August 15, 2016 at 8:52 am
    Donald,
    Assuming the Repeater has power and working, look around and see if you find a Microwave Tower anywhere near you. I had the same thing happen at Prevost in Nashville and it was the Tower causing interference. When you cycle through the tire position, is the pressure shown or dashed lines —-.
    August 15, 2016 at 7:55 pm
    The repeater is hard-wired to power. All sensors are working now. Some of the sensors were showing pressure and some were showing — while driving from Iowa. When we reached Rapid City, SD, all the sensors registered — and the monitor had solid red lights at the sensor positions. We traveled several miles today before all the sensors registered correctly. We will watch for towers and see if that is the problem. We will keep you posted.
    Thank you,
    Donald
