PRESSURE PRO PULSE
I resisted the installation of a TPMS (tire pressure monitoring system) for a long time. Initially the systems had reliability issues with the sensor seals and that caused the loss of air pressure in the tires. That issue has been resolved for a long time so that is no longer an objection.
But I also have multiple toads and until the Pressure Pro Pulse became available changing toads was a problem because it involved reprogramming the sensors depending on which toad was being used. That issue is now a non-issue because the Pulse has a screen that allows you to select one of four toads.
Last November I installed the Pulse and because it had the newly developed sensors with an updated temperature sensing feature a few problems arose. It seems the new sensors need a completely different antenna than previous versions and our XL and XLII stainless bodies adversely affect signals. It is not likely the H3 is going to be a problem. A new antenna has resolved sensor signal problems as long as it is installed in the correct location and is well grounded.
I learned working with Pressure Pro that the company is very supportive of the customer and they jumped through a lot of hoops to make sure any issues I identified were resolved. They can and did review my Pressure Pro System Logs which I could download to a micro SD card, and email to them. We were able to verify signal strengths and review all alerts proving the system as installed is reliable and works. As a bit of a non-believer I frequently verified the pressures the sensors were reporting with my digital tire pressure sensor and I was always within one or two PSI of one another.
What makes a TPMS so important in my opinion was what I learned at the Michelin seminar a couple of weeks ago. While we were doing forensics on failed tires it became apparent air pressure loss or high temps or both were the principle causes of the failure of very expensive tires. So if we can catch issues before they reach a dangerous level we not only are going to benefit our wallets, we are going to stay much safer.
Tom doesn’t know I am posting this, and there is no truth I am sucking up to him for a bigger share of the dues money we collect. I am posting this because if you do not have a TPMS at the very least you should consider calling Tom and discussing your needs with him. He has been selling Pressure Pro for many years and can guide you regarding the best one for your needs. He did promise if he sells enough TPMS systems Nancy may get slides.
If you do not have or want a TPMS, at the very least you should check tires every time you are going to drive the coach. At rest areas use your IR gun to check tire pressures, with any tire above the normal temps from the other tires a possible indication of a loss of pressure or something causing heat such as a dragging brake. A failed tire can be a serious problem and in some cases cause loss of control or do a lot of damage to the coach.
