  • Pressure Pro Praise
    Posted by Hugh on May 25, 2017 at 3:15 pm
    I left my coach with Jeff at ETLC a couple of weeks ago for my annual oil change and lube for bothe engines. When I went by to pick it up today I parked my Toad in front of the shop, about 100 feet away from my coach. When I went out and cranked up the coach, and was about to pull out, my Tire Pressure Pro gave a “low tire pressure” alarm. When I scrolled down I found the alert was for driver side rear tire on the Toad, even though it was no where near the bus.
    I pulled the Toad into the shop and they found a metal object had gone completely through that tire. The Pressure Pro had saved me from a probable big problem had I hooked up and hit the road.
    Thanks Pressure Pro. You saved my bacon!
    Archived replied 9 years, 5 months ago 2 Members · 2 Replies
    May 25, 2017 at 7:31 pm
    Pressure Pro = peace of mind!! Don’t leave home without it!
    May 25, 2017 at 8:40 pm
    Good report Hugh, just think of the outcome if you didn’t have the PP. I’m guilty of not paying much attention to my toad pressures when towing, so for me, the PP will save my bacon hopefully.
    You guys without Pressure Pro need to contact me, click on the photo below.
