  • power steering pump
    Posted by Archived on May 1, 2015 at 8:02 pm
    Started up yesterday. No steering at all. AW–ap. Pulled pump-looked great inside. Noticed something odd the nut had backed off pressure relief valve. The locking nut had lost it’s hold. Solution: new 5/16 by 24 thread locking nut=all is good in busland. Simple if you catch it but wonder how many have spent big$$$$ for pump for same reason. Will pressure check and reset pressure next time I work on bus. On a previous coach with a 8V92 the 30 cent O ring failed and a busnut at Choo-Choo rally that works on a fleet of buses said you want a new pump? or just the O-ring. The 89 with that set up you could still steer. Now the one that just tested me was a 98 with a 60 series and trw pump. I really don’t think I could man handle it far. FWIW Bob
    Archived replied 11 years, 6 months ago 1 Member · 1 Reply
  • 1 Reply
    May 2, 2015 at 9:00 am
    Bob,
    My steering seems a bit heavier since I
    did the engine swap. I used the TRW pump that was on the Series 60
    engine. I haven’t done any research to find out if there’s any
    difference in pressure output between the old pump and the newer pump on
    the Series 60. Don’t happen to know do you?
    Thanks,
    Ken
