  • Power issue after dead fault
    Posted by frank on July 25, 2020 at 9:46 am
    Ok so a stupid little chipmunk got into my air compressor compartment and ate the power cord causing a dead fault against the frame. I rewired the air pump to remove the fault but still no function from the pump just an arcing noise from the pressure switch. But not actually kicking on the pump.
    also noting a loss of voltage on the ac input from shore power, after the transfer switch as there is 120v at both legs at the switch, but showing 93 on one leg at the display panel. I’m looking for some areas to check any help is appreciated and I will update as I find the issue.
    Marshall replied 6 years, 3 months ago 3 Members · 2 Replies
  • darrell
    July 26, 2020 at 9:47 am
    Any idea how/where the critter got in. Found leftovers from mice in my coach from the previous owner. Thankfully haven’t found any damage, I have sense devoted a lot of time closing up a lot of small holes
    Chuck
  • Marshall
    July 26, 2020 at 6:53 pm
    It appears she went in through the holes in the six air cover as they are round, her body was found near the inverter shorting out one leg of my shore power as well, power is now back up and air compressor is working, now to fix my latest lean while in road mode on the left rear as it is dumping when in road position key on
