  • Power cord
    Posted by Thomas on April 6, 2014 at 12:43 pm
    I just moved my bus to a new storage location and when I went out today I noticed that I had forgoten to plug it in.
    I tried to use the switch to power out the cord and nothing happens. I can’t get the power cord out to plug it in. I tried operating the switch in both directions but nothing at all happens. I looked for a circuit breaker or fuse but did not find one. The coach batteries are still up and running the gen does not make a difference. Is there a way to manually override a power cord so I can get it out and plug it in?
    Roy replied 12 years, 7 months ago 3 Members · 2 Replies
  • Ronald
    April 6, 2014 at 3:13 pm
    I just checked mine and you can manually pull it out.
  • Roy
    April 6, 2014 at 7:27 pm
    I found the motor and storage under the bed along with the controls. I turned out I had popped a breaker which I finally found. Prior to finding it I tried pulling the cord. It was very very hard to do but could be done. Maybe someone larger and stonger could do better but it took all I had to pull enough out to plug in. Once I found the circuit breaker all was good again.
