  • Porch/entry light???
    Posted by Tom on October 28, 2015 at 12:37 pm
    Anyone done anything to change this small porch/entry light to something bigger? This one cast a bit of dim light right at the door and that’s all. I’d like to have something that would light a larger area.
    Archived replied 11 years ago 4 Members · 7 Replies
  • 7 Replies
    October 29, 2015 at 4:47 pm
    The photo is not coming through. However, I may have addressed the same issue. Our 2006 Prevost XLII has the small dowlight at the entryway. The light used was originally designed as a Ford truck bed light. I removed the incandessant build and secured an LED light panel inside the lense of the original light. I then connected the 12 volt leads from the panel to the power cables for the original light and the result is a very bright, white light within the original housing.
    October 29, 2015 at 6:13 pm
    Hey BTom,
    That light is a cargo light from a Chevy/GMC 1988-1993 truck. The LMC Truck part# is 37-4324. The new lens is much clearer than the ones that have been on my bus for 14 years… I have also seen the LED bulbs put in these new lens and they are pretty bright..
    Steve
    October 29, 2015 at 9:09 pm
    Could this be the light ? PERKO marine part number 0965DPOCHR
    PERKO Horizontal Mount Stern Light, 2-3/8″ Outside Diameter x 1-5/8″H
    Ichanged out the bulb to LED. Perko was the original light, screw holes line up.
    October 30, 2015 at 8:55 am
    Thanks, Guys…
    Yes, that is what it looks like. I think I will take it off and go with the idea of a brighter LED replacement…that sounds like the most conservative plan. I didn’t really like the idea of some huge big fixture hanging there…but I did want more light.
    I give that a whirl!!!ty
    October 30, 2015 at 6:11 pm
    Sorry about that BTom,
    I don’t know what made me think you had an XL…. I guess I should have read a little closer!!
    Steve
  • Dorel
    October 30, 2015 at 8:23 pm
    Thanks Al, coach looking pretty good, ordered fixture from boatersland, what LED u ordered, part number please/supplier?
    October 31, 2015 at 1:06 pm
    Festoon bulb # DE-3175 LED …. 4 LED bulbs in cool white. Also available in natural white.
    Available from ;
    http://www.superbrightleds.com
