Polybutylene Gray Water Pipes
I thought it might be worth starting a new thread from one that
led to a discussion about the flexible gray pipe used by many converters for
the fresh water systems. This product is most likely Polybutylene. Due to a
high number of failures in the housing industry and a huge class action suit
win, this product stopped production many years ago.There’s probably not a big concern in your coach application to
do what most home owners did and that’s total replacement of the gray pipe. The
failures were a result on one of three factors or a combination of those
factors. UV exposure (not a problem in a coach application), crimp style
fittings (maybe a problem with coaches) and prolonged exposure to chlorine (be
careful when sanitizing your water system).The bad news is you can’t find new replacement Poly-B and even
worse Poly-B fittings are no longer available.
It’s not all bad news though.
Zurn’s PEX product is a similar although different product than
Poly-B. It comes in red, blue, and milky
white. It’s has a high heat tolerance
allowing it to be used directly attached to hot water heaters. Just keep in mind that PEX and Poly-B
connectors are not compatible.If you have a fitting failure or need to add to your water
system there are conversion fittings.
Shark Bite brank makes a conversion fitting that requires no tools
although you need to have a clean cutting tool.
They are a bit pricy, but are effective.
Here’s an example: http://www.sharkbiteplumbing.com/sharkbite-u4008lf-polybutylene-conversion-coupling-1-2-x-1-2-lead-freeAnother conversion fitting is a crimp on style. These use an inexpensive copper crimp ring or
an expensive stainless ring. There are
special tools used to crimp these connectors and range from over $150.00 to as
little as $25.00. The $25.00 one
requires the use of a 10” vise grip.
Here’s an example of one of these conversion fittings: http://www.pexsupply.com/HydroPEX-H140500-1-2-PEX-x-1-2-PB-Coupling-5339000-p
and crimp ring tools: http://www.pexsupply.com/PEX-Crimp-Tools-Rings-693000
.Flair-It may have conversion fittings, although a quick web
search only led to finding ¾” conversion adapter insert. Quest may be another source, although I didn’t
uncover anything doing a web search.
