  • Patio Electric Grill Recommendation
    Posted by DON on May 29, 2015 at 9:41 am
    I need a portable electric grill. Any recommendations? There is a L18-20 120/208v 3 phase 4 wire receptacle in my curbside #2 basement that I assume is for a grill.
    Dan replied 11 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
    May 29, 2015 at 12:15 pm
    That is a 220v 4 wire system not 3 phase….
    May 29, 2015 at 3:00 pm
    I installed a Kenyon. I ran across the brand looking at high end boats to see what those folks were installing. They are available in 110 or 220 for built in or portable. It claims to be drip less and to my surprise it really is. The grills comes off for washing and I have been very pleased. I had only used charcoal or wood grills in the past and was very doubtful about whether I would like electric for grilling. It has been great. I also installed a Kenyon single burner by the grill and found it well worth it. I do wish I had spent the extra money for an induction burner . I am very convinced that being a 220 model makes it perform to a much higher level.
  • Rudy
    May 29, 2015 at 4:52 pm
    I decided to turn the existing one 220v receptacle in to 2 – 110v receptacles w/usb chargers.
    Most things in life run on 110v.
    The Kenyon grills look great.
    Thanks!
    May 29, 2015 at 8:34 pm
    Don etal wrote: “110v receptacles w/usb chargers”
    I’m thinking about doing that with all the receptables in the coach. Anyone else do the same thing? I do like the GFI/GFCI receptables with little LED lights which tell you if the receptable/circuit it hot or not.
    I’m also looking for a 12volt to USB outlet, device, etc. that could be hardwired into the coach. It seems like the only thing I can find are the ones corded to a cigarette lighter.
    May 30, 2015 at 7:42 am
    May 30, 2015 at 11:00 am
    Thanks Joe. That was very helpful. I’ve done many searches over the past months and these are the best so far. I like the one with three holes; two USB and one volt meter. I just bought a new race trailer and the volt meter would enable me to monitor the charge in battery in the trailer for the winch and lights.
  • Dan
    May 30, 2015 at 1:28 pm
    Removed the original 30amp/220v receptacle and replaced with two 15amp tamper proof 110v receptacles, one w/USB chargers.
