Park Brake Valve
Tried to get an answer in pneumatics! I recently replaced the air brake valve. Thought I had everything marked to make the switch over but apparently not. 3/8 yellow line goes to the supply, 3/8 green line goes to the delivery, …. where does the 1/4 inch yellow line go? On the other delivery port or exhaust port at the bottom of park brake valve? There is also a plug. Or does the exhaust port get plugged because the interlock valve does the exhaust? 1991 XL40 w/ 5 speed 8v92. I will post picture off door with pneumatic schematics. Thanks!
