  • Our first problem
    Posted by Dwayne on January 5, 2021 at 6:39 pm
    My wife and I just recently purchased a 97 H-3 45 Featherlight the gentleman we bought it from had it for a year and never even went on a trip so he didn’t have much to tell us so so we are having to figure everything out on our own.
    Our first problem we noticed carpet wet by front passenger seat ??
    So ended up ripping up the floor hoping to find out where the water came from thinking condensation from ac.
    I’m sure I will be on here asking plenty of questions.
    Robert replied 5 years, 10 months ago 11 Members · 14 Replies
  • 14 Replies
    January 7, 2021 at 7:50 pm
    have you driven through the rain recently? I’m wondering if it’s water coming from the wheel well?
  • Jeff
    January 7, 2021 at 10:12 pm
    Look for leaks around the trapazoid window or leaks from the seam between the front fiberglass cap and the bus roof. I have had both
  • Jeff
    January 7, 2021 at 11:45 pm
    From owning a no slude H in the past, leaking could eother be the trapezoid window or up top where end cap meets main roof.
    Isnt that the same paint job as George and Corey’s bus. I know when the bought their’s they said there was a twin.
    January 8, 2021 at 7:45 am
    Hello Roy & Jim – you each mention the trapezoid window. I have a TINY, single, thin line of water that will come in from the top of the passenger trapezoid window, and also the window behind it. Both are so small, they appear to be condensation drip, yet are not. Neither “line of water” even makes it completely down the glass ever.
    I have been on a ladder & roof with a flashlight yet do not see any spots where this tiny bit of water could come in. Have you successfully addressed a trap window leak?
  • Chad
    January 8, 2021 at 7:56 am
    Dwayne – CONGRATULATIONS with your new bus! Looks great!
    regarding the leak, under my bus, I can see plywood covered by spray foam. As already suggested, recommend carefully inspecting from ground upward and also where various structure components penetrate the subfloor.
    1984 96" with 8V92TA
    (remodeled Liberty Coach)
    Greenwood, MO
  • Ronald
    January 8, 2021 at 10:26 am
    I love the paint job, Very nice look
    January 8, 2021 at 10:33 am
    I can’t believe how blessed we were to find this amazing bus
    January 8, 2021 at 9:45 pm
    Water leaks are wonderfully confounding. Bus roofs, or trapezoid window antennas, horns, spot lights, marker lights, a previous owners unfilled holes can all suspect. In some cases, water even travels up hill
  • Robert
    January 9, 2021 at 9:21 am
    Since water leaks can enter and travel long distances before appearing the best and possibly only way to find the leaks is to pressurize the coach interior. If the coach has OTR, open the fresh air baffle at the evaporator coil, or if no OTR rig some means of using a high volume fan blowing air through a window or opening like the toll window.
    Then with the chassis pressurized start spraying soapy water near where the leak might be and look for bubbles.
    With this procedure there is no guesswork and sometimes leaks that do hidden damage are found also.
  • Dwayne
    January 9, 2021 at 4:06 pm
    Putting flex seal on hoping this takes care of it
  • al
    January 10, 2021 at 10:58 am
    Dwayne, You have OTR so take advantage of that, pressurize the chassis and use soapy water everywhere you think water can enter, from around windows to roof penetrations to any seams, including around bays.
    It is far better to take the time to identify possible problems than to wait until you need extensive (expensive) repairs.
  • Dwayne
    January 10, 2021 at 4:48 pm
    Jim, Geo and Corry have a Cat head instead of a Dolphin. Plus, I agree with the Trapezoid window, I had to re caulk mine on both sides due to leaks when a hard blowing rain.
    January 10, 2021 at 4:51 pm
    Jon, on my H3-45 Vantare I cannot pressurize the coach because I have 2 automatic vent fans in front to cool the electronics in the overhead and 2 in the back to cool more electronics. When it gets hot, they come on and suck the hot air out. Surprised that it doesn’t seem to affect the AC when parked.
    January 10, 2021 at 5:14 pm
    Flex Seal will degrade in sunlight rapidly. No UV protection at all.
