  • OTR idler bearing
    Posted by DON on July 9, 2018 at 7:44 pm
    Time to again check everything that the belts spin on the DD60. So, I took all the belts off. All was well except for the bearing in the 3″ dia lower OTR ac idler. It sounded a little dry. I took it off, knocked it out, and found one locally for $50, they cost $20-30 online. The brand I bought is JAF. The pt# is W304-2RS. Its inside bore is 20mm, the outside dia is 52mm. The width is 22.2mm.
    The old one is on the left.
    Your results may vary?
    Ronald replied 4 years, 6 months ago 7 Members · 8 Replies
  • 8 Replies
    July 9, 2018 at 8:26 pm
    Thanks Don, for that valuable post. Changed both of those idler bearings last fall at about $70 each. Will keep your reference for future use.
  • al
    May 19, 2021 at 9:54 pm
    Decided to change 2 more the idler pulley bearings. One in the 5″ double groove pulley for the OTR ac compressor. The other is for the clutch fan. The Prevost pt# is 507014 – $18 ea. Dimension is 20mm x 52mm x 22.2mm. Another pt# is 5304 2RS, available online from many retailer. JAF brand pt# w-304-2Rs, like I used before, will also work.
    Your results may vary.
  • Chuck & Katrina
    May 21, 2021 at 10:12 am
    Hello Don – So nice to find at home as opposed to on the road!
    Leesburg, FL
    May 21, 2021 at 12:34 pm
    Did you need a press to get them in/out?
    Chuck
  • Ed
    May 21, 2021 at 10:00 pm
    I used a press to get them out, but a hammer and socket(or whatever) will work if a press isn’t handy.
    I used a socket, and hammer going back in.
    Good snap ring pliers are needed too.
    Pay attention to the spacer placement/orientation when taking things apart. Make certain to put them back together the way it came apart so the pulley and the belt(s) aligned properly with the other pulleys.
    May 11, 2022 at 3:54 pm
    Don, A year ago you posted about rebuilding your OTR A/C idler pulley, a 5 inch 2 groove pulley. Do you have a part # and where to purchase. Thanks in Advance, Darrell in Dallas,Texas
    May 11, 2022 at 5:14 pm
    Darrell/Dmac:
    I didn’t change the pulley. I changed the bearing in the pulley. Part#s are in this thread in my previous post. The pulley you might get from PrevostParts or a salvage yard.
  • Ronald
    May 12, 2022 at 10:13 am
    Don, I ordered the OTR A/C idler pulley bearing, Prevost part# 507014 from Prevost Parts, $140. Thanks for your help and contribution to this forum. Darrell
