  • OTR AIR 99CC 40 ftI
    Posted by Roger on April 22, 2014 at 7:25 pm
    I quess my question should directed to Gil since he also has a 99CC. I need the amount of r-134 for the galley and bedroom ac [seltec tm-31} I use 6 lbs 2 oz for the dash air.
    AL replied 12 years, 7 months ago 5 Members · 5 Replies
    April 22, 2014 at 8:02 pm
    Between 6 or 7 lbs.
    Low pressure side 24 lbs
    High pressure side 284 lbs
    Post your email address and I will send you the service manual.
    I really have to clean my condensors to keep the pressures down and to make the system work properly. Being between the drive wheels makes them hard to get to.
    April 22, 2014 at 9:26 pm
    I’ll look at the engine door label tomorrow. I have heard the same about keeping the condeser clean. I’ve never had that problem even after driving the dusty roads of Alaska. I did pressure wash it when I returned. FWIW, the PO of my coach upgraded the fans on the condenser. I have no basis for comparison, but maybe the new fans move more air.
    Charles, you have a manual on servicing the CC OTR Air?
    April 22, 2014 at 9:32 pm
    Hey Gil, I have the service manual for the TM 31 compressor, nothing on this from CC.
    April 23, 2014 at 9:15 am
    Thanks Charles & Gil for info. Gil info on fan upgrade would be helpfull. one fan is not working probably need too replace both. thanks again.
  • jack
    April 23, 2014 at 10:10 am
    The label on mine, although a bit hard to read, says 128 oz.
