Operators Manual
Posted by Roger on February 2, 2013 at 4:22 pmNew to board and bussing. Church recently acquired 1990 Le Mirage and we are in need of an operator manual.
Any assistance as to where and how much would be appreciated.
Contact: hrgay@bellsouth.net
Thanks in advance
Corey replied 12 years, 6 months ago 5 Members · 7 Replies -
Here’s an answer that is not an answer.
Go to this link http://prevostparts.volvo.com/technicalpublications/en/pub.asp
You will find the information you are seeking is not there. But…..if you play around and enter incorrect information such as the model year for a newer coach you will get some good information. For example, except for major redesigns such as going from an XL to an XLII Prevost makes incremental changes so while you may not be able to get what you need for a 1990 coach which was likely a 40 footer powered by a 2 stroke engine, you might get information for a later model with a 2 stroke engine, or you may have to use information for a coach with a Series 60.
The important thing to recognize is you might have to compare the information that is available to your coach. Some information will be valid, but some may supercede what you have. The basic information is likely to be accurate enough for your purposes.
The information you can harvest from the link above will be far better than nothing.
Don’t forget, you can always ask questions here. Sometimes we may actually provide a correct answer. (Almost just kidding about that.)
Thanks Jon, will try to follow directions and dig out info. Roger
PA-1082 1989-2000 is the maintenance manual for xl buses and motorhomes from 1989 -2000.
Access this at the link Jon provided.
Go to the Technical manuals section.
Mark vehicle type as “XL Bus”
Check “Maintenance Manual
Do not enter a date
Josh,
Maybe someone with a similar vintage coach with the owner’s manual will copy theirs and send it to you. I suspect anything from late 87 (first introduction of DDEC) to 93 or 94 will be a big help.
Josh, I used to have a ’90 converted by County Coach. I never had any chassis manuals from Prevost but I did scan and save the Country Coach house manual before selling and can send it to you if yours is Country Coach. It won’t be of any value to you if yours had a different converter. Note that there are several other ’90 XL owners who post on this site. Send me your email address if you need the CC manual. Good luck with your new bus!
Bryan thanks I’m actually converting the bus . It will be a big challenge but it’s something I’ve always wanted to do I’ve jest started and this chassis seem to be in fairly good shape I would be very interested in your manual if you could send it to me I would greatly apperecate it. Thanks. It may give me some good ideas I’ve spent a lot of time at rv shows and looking diffrent designs hoping to get some good ideas on how I want it set up My email is josh@apexspecialized.ca Again thanks to Jon and Bryan
Josh, I sent you the manual via my work email because the file is large. Email me through this site if you have trouble opening it.
If you haven’t already, you should check out the “Homebuilders” tab on this site. There are some very knowledgable folks who are in various stages of the project you are undertaking. Good luck!
