  • old air bags
    Posted by Rick & Denise on October 16, 2012 at 6:05 pm
    Started replacing my air bags and brake chambers this past weekend. I got half way through and will finish next weekend.The air bags are dated 1995 so I presume they have never been replaced. Much to my surprise there is cracking in the rubber. With that in mind would they be worth anything or should they be chucked. Rick
    Archived replied 13 years, 10 months ago 9 Members · 18 Replies
  • 18 Replies
    October 16, 2012 at 6:26 pm
    chuck ’em
    October 16, 2012 at 7:02 pm
    Rick,
    Dump them… I cut one of mine open just to see what the inside looked like and other than the bump pad being banged up, they looked like new and they were 15 years old.
    October 19, 2012 at 11:08 am
    Rick,
    I kept a couple of my old ones and installed a shut off valve and air chuck, now I have a couple of air jacks that really work great.
    October 19, 2012 at 3:36 pm
    Damn, wish I would have thought of that…
    October 20, 2012 at 4:04 am
    Dan Can you send a pic. Sounds interesting. Rick
  • David
    October 20, 2012 at 8:46 am
    Tom, now look what you have done! 🙂 Or did you mean to add a mn and cut the le to my name?
    Rick, I’ll post a photo soon.
    October 20, 2012 at 6:02 pm
    Here is a couple of photos of the air jack. The only modification is to cut one of the mounting bolts off and grind it smooth as shown in the red circle.
  • Eric
    October 21, 2012 at 6:39 am
    Thanks Dale. Tom if you want some of my old air bags you are welcome to them. I can give them to you
    when I see you in Fl. in Jan. or if you are will to pay for shipping I can send them now. I plan
    on keeping 2 so the other 4 are available. If anyone else would like them just say so.
    I am all done for now til next year. I just replaced air bags,brake chambers and shocks. Rick
    October 21, 2012 at 7:16 am
    Nice photo Dan:)
    Thanks Rick, I just bought an air/hydraulic jack, so I’m good.
    October 21, 2012 at 12:10 pm
    Yes bought one as well and just used mine for the first time and love it. Rick
    January 3, 2013 at 2:34 pm
    I am ready to replace the air bags and from looking at this article it seems that some of you replace the entire assembly as opposed to just the bags. Is that what I need to do? I can see an advantage to having the complete assembly new, but is that more expensive to do? I would suspect that mine are 21 years old.
  • Tom
    January 3, 2013 at 4:14 pm
    Tom Are you talking about replacing just the rubber part of the air bag? If so I don’t think you buy just that part.
    Rick
    January 3, 2013 at 7:06 pm
    They come complete, bolt on item. Prevost is the best price.
    January 4, 2013 at 8:00 am
    That sounds good. The reason I ask is the maintenance manual shows how to remove the rubber part from the assembly for replacement and the part is listed in my parts manual as well. Replacing the whole assembly sounds much easier.
  • Tom
    January 4, 2013 at 8:01 am
    Depending on your future plans for ownership you might want to consider refreshing your entire suspension system while you are at it. Over time as the components age they stop working as intended. The shocks lose effectiveness, the Norgren valves start to leak and the air bags either get rust leaks in the bottom “can” or they leak due to cracks that begin to form around the bottom where they flex and roll. In extreme cases an air bag just gives up and bursts like a tire blowout.
    So if your coach ownership is intended to be long term you will get a lot of peace of mind replacing Norgren valves, maybe ride height valves and shocks while you are in there doing the air bags. If you average 1 1/2 hours per air bag add another hour to the labor and you can get everything else done also. Do that and you probably have at least 10 years of peace of mind.
