  • Posted by Allan on June 11, 2018 at 10:11 am
    Ok this is almost too embarrassing to ask, but before I break something I guess it is better to ask now. How do you remove the oil cap pictured below?
    Sid replied 8 years, 5 months ago 3 Members · 2 Replies
  • Harry
    June 11, 2018 at 10:50 am
    Unscrew the “T” handle a couple of turns and it should pull out. The T handle tightens against the rubber seal causing it to expand against the tube.
    Doug
  • Sid
    June 12, 2018 at 8:52 am
    Allan,
    You also have a oil reserve reservoir that hold a couple of gallons maybe. That you can use to add oil, ( just in case you did not know ) It is the small door on the right above the engine bay doors. Follow the black hose down from it inside the engine compartment and there is a red valve to turn to let oil into the engine. There is a small site tube on the side of the reservoir to monitor how much oil is going in. It should have markers on it for half gal/ gal. Have thought about adding marks on mine.
